Discuss Glitter grout in the UK Tiling Forum area at TilersForums.com.
P
Perry
Using this for the 1st time tmrw.....any tips/advice, do's/don'ts?????
Thanks in advance
kilty55
1,113
edinburgh
hello,wear throwaway gloves,and be prepared to keep your glittery float and sponge in there own special box from now on:drool5: good luck,,what kind of tiles are you grouting?
Daz
Is this the Mapei glitter grout?
If so, mix it exactly as per the instructions on the pack.
Work small areas at a time and wash off with warm water.
Be prepared to throw your sponges away afterwards as they will be full of glitter :smilewinkgrin:.
P
Perry
Good thinking on the gloves :thumbsup:
Not sure of the manufacturer, they are black/dark grey porcelain 400x200mm on the wall (just one wall getting done) and 313mm 'ish' square on the floor
P
Perry
No not Mapei, it comes in a tub, 3 parts, only 45 mins working time!!!!
I'll find out exact details of it tmrw
Spud
make sure you have plenty of emulsifying pads,I use detergent in the water and lots of clean sponges,I always return for a final clean down the following day to remove any residues :thumbsup:
P
paulyoung666
all of the above applies , and if possible try and make enough grout to do the whole lot in one go , and be prepared to be a glitter fairy , the stuff gets everywhere :lol:
tfs
Work as clean as you can, the less epoxy you leave on the tile as you spread the easier it is to clean.
Be carefull not to get any grout on furnature or any other areas as if you do it will be a nightmare to remove.
mix with a mixing paddle to help get a better mix.
In my experience the grout has always looked less glittery during mixing than what it does once applied to the tiles so, be carefull not to add too much glitter unless this is the effect you are hoping to achieve.
Bare in mind that this stuff is expensive so if you cant grout a full tubs worth at once it may prove to be even more pricy than you think. (get another pair of hands to help if needed)
:thumbsup:
P
Perry
Thanks all for the replies :thumbsup:
Managed to get it done no probs, wasn't as bad as i thought, cleaning up was a bit more of a chore though!
Not sure its worth the £80 per tub the customer paid, could you not just add glitter through normal grout??? Or is that just daft :lol:
Reply to Glitter grout in the UK Tiling Forum area at TilersForums.com
