Jakarta 600 x 300 Porcelain from Tile Giant
The porcelain tile was a very rough, matt faced tile with sort of pores on the surface. It has a different colour on the back of the tile. Kind of like a porcelain backed tile with some kind of glaze on the face.:thumbsup: very matt as oppose to satin finnish
I fitted this tile in a bathroom and decided not to use a few of the loose tiles as they had grime/ dust etc on the face which was a nightmare to clean, so I sealed the rest with Glaze protector. I didnt think Matt stone was realy suitable at the time so I chose the glaze protector.
Ahh just re-read.. yes unglazed and not polished...cheers...
The glaze protector would be ideal...
We did a lot of testing before recommending a product. We also spoke to the manufacturer and LTP. The result was Mattstone would be the best product for it.
I did a few tests myself and was surprised how well the Mattstone worked.
Jakarta is a double loaded porcelain which is why it has the appearance it does, I.E the top 2-3mm is the same colour as the surface and the bottom is a different colour.
It is made with two layers of porcelain that are pressed together and then fired.
It is good to remember matt... as long as LTP say it will work then ok by me..:thumbsup:
I must say I was surprised at the result. I figured the particles in Mattstone would be too big for the pores in the porcelain (I had previously thought that the MPG Sealer would be more suited), guess I was wrong :lol:
That is what i thought... too thick a sealer for the surface tension of the vitrified tile..
But like i said... nice to know..:thumbsup:
Thanks for the information, have done 2 coats on 2/3rds of it and it looks and works just fine.
Basin is now fitted and the bath sealed up, so just the shower and flooring to sort out ! :thumbsup:
Thanks again, and have informed the guy at Croydon Tile Giant which sealer should be recommended !
Best Tile Suppliers | Tile Supplier Discount Codes
pault123,
pault123,
pault123,
pault123,
