Cutting Quarry Tiles
Ajax123
I am about to embark on retiling an outside passage at my home. I am going to use Wickes quarry tiles (mainly because they are cheap and I am tight). I will have to cut both sides of the passage to fit them in as I am setting out working from the centre outwards so it looks even when finished.
It means quite a lot of tile cuts. I normally use my 4" angle grinder to cut half way through and then break the tile. Other than buying a table cutter (Can't justify the price) is there an easier way to cut these sort of tiles.
is it a shared passage if so why not put the cuts to your neighbour side an d half your work ,just an idea m8 :lol: :thumbsup:
A hand scribe and pin hammer will work.....Scribe the face of the tile and tap on the back of the tile with the pin hammer on the score line...
Make sure score lines is in the same direction as any ribs on the back of the tile.
Thanks for the replies so far. I will have a go at scribing and using a small chisel.
No Gooner it is not a shared passage otherwise I would probably have done as you suggest. I might even have just tiled my half :lol:.
I have just started taking the old tiles up and they are all coming up perfectly clean so I will use a few of them to practice on and then reuse to good ones. They are fortunately the same as the new ones I am getting.
I forgot till the Mrs reminded me a few minutes ago:mad2: I have a manual cutter I bought years ago to do my bathroom. Will dig it out and have a go with that but I think the tiles will be too hard for that.
If it turns out ok I might even post some pics. If not I'll put a rug over it.....:lol:
go and hire a suitable heavy duty manual splitter cutter, im sure the cost of it will outway the cost of the ones you waste, speculate to accumulate.
Where would I hire such an implement...and do you have any idea of the cost - ball park figure close enough.
Ajax123,
tfs,
Ajax123,
tfs,
