Discuss B & Q Walk in shower in the UK Tiling Forum area at TilersForums.com.
stryd
Hi to all just joined
Next week i plan to rip out my bath and install a walk in shower that i bought from B&Q called ZONE 1 its 1200 x 800mm
After reading and researching shower fitting i thought i had it sussed by fitting the shower tray in 1st and then tiling down to the top leaving a few mm to silicon seal after...but on reading the instructions for the shower cubicle it says THIS SHOWER BASE CANNOT BE SET INTO THE WALL IT YOU MUST TILE THE WALL 1ST AND THEN FIT THE TRAY TO THE TILES AND SEAL....i have checked the glass panels and fittings and there is no room for any of the fittings to be secured to the tray if the tray is set into the wall..??? Has anyone fitted this kind of shower before---maybe it will be ok if i plasterboard the walls square and put loads of silicone between tray and tiles....
davy_G
Hi stryd,
I suppose every one is different. Is there a customer or fitters helpline on the instructions? If so give it a call to clarify. Most standard shower trays are fitted first then tiled to, but I have read on hear about the opposite being the case.
I cant picture it but i like to tank everything is walk in showers, dont like the idea of siliconing a big gap.
Any photos?
Good luck whatever the outcome, a few more experienced fitters might be along having used some of these formers.
Daveyboy
There are some products on the market that do require you to tile the walls first then fit the tray..in this event, the walls have to be perfectly straight and the corner a perfect right angle, otherwise you're left with gaps that need filling with silicon, then you need to fit a corner/edging strip against the tiles and tray...
DHTiling
I have seen a tray like that...an en-suite i did had the same type...:thumbsup:
I had to tile the floor first as well...then the tray was sat on the tiles and against the wall ones..:thumbsup:
This is the said shower..but you cannot see the tray in the pic..
Time's Ran Out
If the instructions tell you to tile the walls first (and as Dave suggested possibly the floor) and you've checked that there will be no room for tiles if its set into the wall then that's it!
The only suggestion I would make is not to use plasterboard but set the walls up square with WEDI board.
Timeless John.
stryd
Or tank it..:thumbsup:
I dont think that will help because the tray has a raised lip all the way round which is 12mm high but only 3mm wide at the top....so how can i tank/seal the wall to a 3mm lip ....any ideas
stryd
The only problem is that there is a raised lip all the way round the tray which is 12mm high but only 3mm wide a t the top so its not possible to fit any kind of seal between wall and tray as far as i can see.....
Daveyboy
Hi Stryd..that lip is called an upstand and the upstand normally sits between the wall and the tile so it's strange that the instructions say you tile first and then fit the tray..I'd definately check with B&Q/the manufacturer to make sure the instructions are correct..
stryd
Thanks for your input but i dont think the end panel will fit if the tray goes into the wall because the glass end panel fits to the wall with a double u shaped extrusion and the corner of the end panel fits to the tray with a closed end corner bracket that needs to be screwed to the tray ....dimensionally if the tray goes into the wall the end bracket that screws to the tray ends up on the radius of the lip.....not on the flat..so i think im buggered....ill have to get the walls square and rely on silicon...
On another note the tray is fibre glass and comes with 5 support legs is it supposed to be supported only on the legs or on legs and the outer edge of the tray aswell....somehow?
Reply to B & Q Walk in shower in the UK Tiling Forum area at TilersForums.com
  • Sticky
