Discuss Underfloor heating and then Tiling on top in the UK Tiling Forum area at TilersForums.com.
Shylo
Im due to start tiling a Conservertary (4x4) 2moro and im gonna try and lay the tiles (Slate) on top on the underfloor heating.
Do i put a 10mm bed of Adhesive of top of the underfloor heating 1st???????? and i also put it on back of the tiles as well so it will be 20 mm thick
plz help asap
grumpygrouter
You will be better off skimming with SLC. Try using Mapei Fiberplan. This will give you a great surface to tile onto.
CJ
1,088
Somerset
As above.
Always easier self levelling first.
Then use a flexi adhesive and grout.
If not.......you could use PTB flexi
sWe
I always cover UFH with SLC, for five reasons:
It protects the UFH when you put down the tiles.
It's easier to tile when the UFH is already covered.
You don't risk damaging the UFH when tiling.
The risk of damaging the UFH if replacing tiles, or retiling later on, is significatly smaller.
And finally, the heat is distributed better.
I'd recommend covering the UFH with no less than the thickness of the wires/tubes +10mm, preferably +20mm. Too little and you still risk damaing the UFH if/when replacing tiles or retiling, and the heat isn't distributed as well as it could be.
Shylo
So wat you are sayin is ..........use the SLC then lay the UFH on top of it??????
grumpygrouter
No, lay your heat mats and then skim over the top with the SLC. When dry, tile on top of your nice smooth surface.
sWe
Nope, the other way around. Lay the UFH first, then cover it with SLC. if the wires are 5mm thick, I'd recommend pouring atleast a total of 15mm, to get a 10mm cover.
White Room
Make sure the wires are not loose and are not going to lift when you pour the slc
doug boardley
should this only be used as part of a calorie controlled balanced diet?:grinningelf:
excellent advice from the upper echelons!
Reply to Underfloor heating and then Tiling on top in the UK Tiling Forum area at TilersForums.com
