Discuss What’s the best tiling gap? 2-3-4mm etc in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jkb
Hi,
Second post.
How do you decide what’s the best spacing gap between tiles? I plan on setting 200 x 500 x 8.5mm wall tiles and unsure of what spacers to set between these.
Any advice appreciated
Wayne Brown
As above 2mm on walls if of good quality although I tend to use 3mm more these days especially on floors it gives you room to correct any discrepancy in the tile. Kop
WetSaw
2mm normally but will go down to 1mm when using tiles with a rounded edge and dark biscuit ( if the tiles allow ) otherwise with a 2mm spacer it ends up looking like you've used 5mm!
Reply to What’s the best tiling gap? 2-3-4mm etc in the Canada area at TilersForums.com
Lowpaul22
