Discuss What primer and adhesive - underfloor calcium sulphate in the Tile Adhesive / Grout Advice area at TilersForums.com.
J Sid
You can lay to a wet anhydride Julian?
BAL Flexbone 2Easy is a unique floating uncoupling mat where no adhesive is needed underneath – a truly uncoupled system! Because it is floating, only basic preparation is needed – simply sweep solid, level floors and lay the mat. No remove of residue, bitumen or laitance. No priming needed. Tile immediately to contaminated, stained or cracked screeds and over bitumen. Fast-track tiling on new anhydrite and sand:cement screeds that aren’t cured as moisture evaporates through covering joints.
J Sid
that's what the rep said and the website backs him up.
wet....aren't cured..... Is there a difference?
Reply to What primer and adhesive - underfloor calcium sulphate in the Tile Adhesive / Grout Advice area at TilersForums.com
