What is your choice for retro fit wet ufh
J Sid
There are many different types out there, I have one I recommend.
Which one do you lads recommend / fit and is it different for different substrates?
I can honestly say I’ve never been asked to spec one Julian.
Last time I even supplied an electric ufh system was 2016, and I’ve fitted less than half a dozen since then. 🤷🏻‍♂️
Thanks Marc
If a customer needs retro wufh or electric I
try and spec what I like and if it.
Had a large job last Xmas, 100m2 plus, boards and wire. Spar wanted to supply and fix, I gave clear instructions on what I need to tile it. He didn't think he would bother to tape boards or seal boards before slc. I turn up to a crazy paving floor with slc coming up. Customer wasn't happy when I said I would tile on that. Found some to tile it 3 weeks before Xmas.
So, unless it's done by me or I see it being done by others I won't do the tiling.
Think we all know what I normally use for wufh, just wanted other options and see what other recommend.
[automerge]1570353945[/automerge]
Sparks don't have a clue about what is necessary
[automerge]1570355764[/automerge]
I've never tiled a wufh panel system so cannot offer anything but this is a worthwhile question .
I've done that in small areas marc with electric ufh wires.
The job I'm pricing as type is reto wufh on gypsum screed in a old cottage with no floor insulation, so going for a installation boards type.
I have solfex wufh overlay in my own house and done a couple of the same system for my customers.
Never had an issue and very competitive
Just been looking at there site, no much info there🤔 did you fix tiles to it? If so it looks like they say fix to 6mm ply😳 but not clear at all. It's also a floating floor which I'm not at all keen on tiling onto
its the usual gypsum panels free floating and glued together, screwed down plastic end sections. Then ditra matting and tiled.
J Sid,
Dumbo,
J Sid,
Dumbo,
