Obviously we supply the tile drills that will put a hole into a tile assuming you will be using standard rawl plugs. Hence this product:
Which is used for this type of hole
BUT
If you are going to use plasterboard wall anchors beware that you will be limited to the width / size of the hole that you can poke through.
If you tried to use any type of self drive anchor when the tiles are fitted with our 8mm kit then they will get it stuck. IE this is a self drive anchor.
I would not recommend a self drive anchor (
sorry to the post above) but he IS correct and on the right track in suggesting wall anchors as the solution. What I would suggest is a slightly different anchor.
Thats because the wall anchor that you use is going to need has to fit into through the hole in the tile and into the cavity to expand behind.
Assuming you are not confident the tile and adhesive could hold the weight of a standard rawl plug then you are going to need a wall anchor that expands after installation.
This is a bog standard rawl:
Not man enough for the job? - Then you need a wall anchor
Can I suggest this one? 38777
38777 is (M4) needs our 8mm drill kit to fit it. Once drilled you then slide the barrel of the above through the hole to the back of the tile / plasterboard sandwich.
I'm afraid my suggestion does require the additional purchase and use of tool 38788 to "open" the wings of the anchor for it to grip the back of the plasterboard and thus spread the load.
The M4 size fitting if used in series of say three on a shower screen should have enough guts to hold up.
