Discuss Walls or floors first in the Canada Tile Advice area at TilersForums.com.
Ttt1601
If possible I do walls first as you say why risk it, but sometimes not possible, I'm back on a wet room today that I started a couple of weeks ago, no choice but to do floor first, edging tile with skirt tile matching up, running against the main porc tile in half bond, all has to be perfectly centered, architect's house :confused:
J Sid
todays job, planks going up wall.
WP_20161114_07_59_54_Rich.jpg always floors first, easier to get joints lined up on walls
Rich Midge
598
Liverpool
If the joints need matching I tend to lay the floor first, protect it, then out the walls up as per Julian, find it easier matching everything this way. If not needing to match the joints I'll put the walls in one tile up of a batten, then floor, then put the bottom cut down onto the floor. No right or wrong in my eyes just different ways of doing things.
Reply to Walls or floors first in the Canada Tile Advice area at TilersForums.com
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Sticky
  • Question
  • Question
