Discuss URGENT! need advice TODAY, horizontal staring point (see drawing) in the Canada Tile Advice area at TilersForums.com.
This looks very good here, I was really hoping to avoid these little 5&10mm cuts.
Yes, I've saw this. I think this is the best option so far. I'm also going to draw up an option to see how it looks if I bring the floor tiles up the wall slightly like a 100mm skirting.Go back to the post where I posted your plan on the previous page. You'll see dark blue lines drawn on your plan, these tiles can be reduced by 5-10mm or what ever you need to produce a full tile around the window and no small slithers will be required. Besides, you can't put 5-10mm cuts around a window, it'll be wrong on so many levels.
So, eight full height rows from floor up and small gap at ceiling ? I was thinking of this as well and just put a tile trim around the top. The tiles are matt white and the grout is white the ceiling will be painted white so everything is white so I think a small gap at the ceiling would be fine.I still prefer the original set out with a 10mm gap at ceiling.
You can either add a small cove at ceiling line or even just add another layer of plasterboard to the ceiling, both can be done at a later date,
With only 300mm or so over the window head, a double cut can look bitty.
Just my opinion tho.
Dunno about fine however if you find you can live with it, then it's perfectly acceptable, it's your home after all.So, eight full height rows from floor up and small gap at ceiling ? I was thinking of this as well and just put a tile trim around the top. The tiles are matt white and the grout is white the ceiling will be painted white so everything is white so I think a small gap at the ceiling would be fine.
On the door wall around the edge of the bath there is a 30mm sliver of tile and above the door a 35mm sliver of tile - is there a way I can adjust so these won't be quite so small?Have drawn up all walls and floor
Would love opinions, comments, ideas etc
What do you think?
Reply to URGENT! need advice TODAY, horizontal staring point (see drawing) in the Canada Tile Advice area at TilersForums.com
