Discuss Underfloor heating - to screed or not to screed? in the Canada Tile Advice area at TilersForums.com.
dazlp
Hi, Looking at putting electric UFH down in the kitchen onto an uninsulated concrete floor. Plan to use 6mm insulation boards under the mat, but my question is do I need to lay a screed down over the mat before then laying the tiles + adhesive? Most of the UFH manufacturers offer the choice of both (you need to screed first OR you just apply a full bed of adhesive over the mat (carefully) and lay tiles on top.
We want to keep floor level as low as poss so the obvious solution is to go without the screed. Any one got any advice on pros/cons/experience?
Cheers
K
Kia tiling
Definately latex. Make sure your joint where the cable meets the tail is going to be submersed. Be careful with tape cos you can leave air pockets. The best way i find is spray glue and scrimtape it all down. The scrim allows the latex to fully encase the cable ensuring no failure. The de-coupling combination system like ditraheat, Variopro, DCM-pro are excellent, the future probably. Especially when they bring out a mat with insulation properties!
Dumbo
UFH cables need to be fully encapsulated in some form of cementitious material to dissipate the heat away from the element otherwise it is liable to burn itself out. The runny consistency and high flow properties of SLC make it much easier to fully surround the cable. You don't gain anything by using adhesive only as you still need to get the same result... and KG for KG it is usually more cost effective to use levelling compound because each KG goes further and as an added advantage it makes the tiling go much easier as the floor is flat as a pancake. On top of this, if you ever need to replace a tile, you've got much more chance of being able to do that if it isn't fixed direct to the elements.
Floors are as flat as a pancake if the person using the slc knows what they're doing .
Dumbo
No, that you think my job is easy money
Easiest money I've ever earnt .
Spacey
Funny thing is that's the second floor I've done in that house . The first floor was where the householder asked if I could help him out as the floor he had just had put down by a floor layer was failing
I replace alot of failed and badly fitted karndean/Amtico floors by so called floorlayers who tend to be either contractors who thinking there poor standards are acceptable to domestic customers Carpet fitters seeing £ signs or buinders or other trades trying there luck.
It's a specialist craft to do it correctly and to the highest standards.
In the last 3 years I've been though about 25 floorlayer who just aren't up to standard I can't find anyone who's good enough and to busy to train anyone up.
These same 25 I believe all work for shops now fitting Karndean and Amtico ?
Reply to Underfloor heating - to screed or not to screed? in the Canada Tile Advice area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
  • Question
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
  • Question
