E
EdMac
I think I've managed to create a layout whereby all of my cut tiles are square cutouts. It's possible when I do a dry layout that I'll prefer a different configuration.
One factor will be whether I can get away with a U-shaped cutout or not?
I have 2 pillars protruding from opposite walls supporting an RSJ. I initially wanted to do a u-shaped cutout around them so that a tile lay across the gap between pillars - as this gap has a row of engineering bricks running between it across the floor. It seemed preferable to have that row in the middle of a tile rather than at the end. But then I decided provided the adhesive bonds it's irrelevant and a square cutout is simpler. If I could achieve a u-shaped cutout I'd have a choice to consider.
The tiles are 59x59 porcelain and either 9mm or 12mm thick.
