Discuss Tuscan Levelling System in the UK Tiling Forum area at TilersForums.com.
R
Rob Z
I finally remembered to get a camera onsite at the same time that we were using TLS. Here are some photos . There is a new gun for the straps. This one has an adjustment knob to regulate the tension applied to the strap. The lowest setting barely pulls the strrap. The "S" setting is what is needed to break the strap. This adjustment function is useful because in the past I have accidentally broken straps in place while tightening the caps. THis floor is about 26 sq feet or 2.5 sq meters. I used about $25 in straps or about 15 GBP.
R
Rob Z
The lower-cost strap tightener is useful sometimes when access is too tight for the larger pistol. The new low-cost tool has been improved slightly because the lower handle is curved, which makes it less of a knuckle-buster.
Back-buttering is necessary, but we would be doing that with any large tile anyway. These tiles are 14" x 14" (35 cm x 35 cm for my friends overseas :smilewinkgrin:). These are set with a 1/8" grout joint.
R
Rob Z
I just noticed that the reflection of the light from the window (first photo in first post) is "broken" as it runs across a grout joint. At the time I took this photo, Eddy hadn't tightened the final straps in that corner. THe tile was set close to final position, but the TLS is what will bring it in to as close to flush position as possible. I'll try to remember to take the camera back and get the same spot photographed again for comparison.
Stewart
Cheers Rob..... How do you find the time difference on using this product compared to not using it. I'm struggling to see the point of using it, unless it speeds up install times.
R
Rob Z
Hi there Bob,
I've never been able to conclusively determine the cost/benefit for the TLS strictly based on labor saved vs cost of the straps and gear. If we ever did two floors that were the same, I'd probably set up and do one with and one without, and analyze the results. But most of our jobs are one-off things and nothing is ever the same twice.
My feeling is, however, that we are faster by at least enought to pay for the straps. The real difference for us is convenience and not having to worry about tiles shifting or sagging after they're set. I know a lot of guys here in the US like TLS and use it. I don't know if there is any one here at this forum that has used the products.
Andy Tiler
1,043
manchester
hi rob i am trying the lash system at the moment and it works very well, only you end up with sore hands,i want to try the tls system but its a hefty set up cost,but i do agree these systems save u time. :thumbsup:
R
Rob Z
Hi Andy, I saw the LASH product for the first time the other day. The bottom part of the plastic straps is curved so much that it seems like it would prevent the tile from being set close to the substrate. In use, do you find that this is not a problem?
The bottom part of the TLS strap is flat.
Andy Tiler
1,043
manchester
hi rob no not found this a problem i think the curve helps with bringing the tiles level ,cos your only using your fingers to push the wedges into the clips,i think they also could be good for tiles with various thicknesses,im using them all the time now for large format tiles.but i would like to try the tls system .:thumbsup:
Reply to Tuscan Levelling System in the UK Tiling Forum area at TilersForums.com
