Trim snips / metal trim
What are peoples' opinion of these? I have only bumped into one tiler who uses them and he raved about them, looking briefly at them, they looked as if they cut the trim a bit curved not straight like my usual method of mitre block and hacksaw.
Also i have always used the mitre block and hacksaw for cutting metal trim and metal borders but this can be seriously time consuming plus pretty damn sore on the hands after 4 mitres per corner in a bathroom with windows, what does everybody else use?
Snips will crush metal trims.......i use a mitre block and standard hacksaw ( for plastic trims )... and with metal trims you can also get pre-made corners..this will be quicker and neater than trying to mitre metal....:thumbsup:
Not a fan of metal corners i prefer to mitre them, i was hoping for an easier method. Had my doubts about the snips just aswell i didn't buy them.
Thanks chaps
i did have some trim snips i had them for a few years if you use them right it can give a good mitre and they save time but now i use mitre block and hacksaw
Mitre block and standard not junior hacksaw
i mitre the tiles looks a lot better but this is what i used to use when i had to use trim imo its makes a lot better job than a hacksaw and mitre block 😛ete
Compound Mitre Saw 24" (600mm) - Screwfix.com, Where the Trade Buys
I used one of those for a while, but the cheap ones wear quickly and then give too much play in the action...maybe a more pro / expensive one would be better. I also found it bulky, not something to throw in the toolbox at 5pm on a Friday....
culrossblue,
heswards,
culrossblue,
heswards,
