Discuss Tiling outdoors when it’s wet in the Canada Tile Advice area at TilersForums.com.
553
Tyne Valley, Northumberland
Morning all. I have an outside tiling job coming up (800x400x10mm porcelain) on a concrete slab. The builder has built it with a decent drop and it’s pretty flat. The issue is the weather. I have been told that the base needs to be completely dry before I start as any moisture in the concrete will be locked in and when we get a cold spell it will freeze and the tiles will almost certainly lift.
Given the weather this year I’m struggling to see how I can get this done. Any advice on methods or materials would be gratefully received.
Tile Fix Direct
TF Official Sponsor
733
Aldershot
An alternative is Kerakoll Green Pro with Aquastop membrane. Prevents water reaching the slab, prevents secondary efflorescence coming up from the concrete and is part of their Kerakoll System.
If you need any more info contact Karl at Kerakoll on 07799 70‬3378
H
hmtiling
I wouldn't compare the 2 personally. The green pro should be compared to durabase and ditra. Ditra drain offers sub tile drainage which virtually eliminates freeze thaw and efflorescence risk
Tile Fix Direct
TF Official Sponsor
733
Aldershot
Kerakoll argue that their Green Pro is a waterproof system so if applied correctly no water will enter the subase, and residual moisture in the screed is able to evaporate due to incorporation of a breathable sheet.
H
hmtiling
So the same as ditra and durabase when taped then and not comparable to ditra drain?
Reply to Tiling outdoors when it’s wet in the Canada Tile Advice area at TilersForums.com
