Discuss Tiling on masonry in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jimbow
Hi folks,
Is it possible to tile straight onto a masonry emulsion painted wall. The render and skim on the wall is sound. I am asking with regards to above my kitchen worktop and around a shower
Thanks in advance
Jim
Spare Tool
The paint needs removing Jim, try a wet sponge and scraper, or if that doesn't work 50 grit sandpaper...
What size/type of tiles?
Spare Tool
Square edge plastic in the colour of your choice (personally try and go similar to grout) is easiest to cut and mitre..stainless looks better imo but plastic a bit easier, call into your tile supplier and see what they have in stock..
Jimbow
Square edge why didnt i think of that, for years i have been using the round over stuff which has always been a pain and never looks right. Does the square edge go over the tile or does it but up to it?
Have been advised to use SBR on the walls prior to tiling what you reckon? Whats the best adhesive for tile on masonry?
Spare Tool
Fit trim flush with tile..
Adhesive wise, would always recommend a slow setting cement based bagged adhesive,.. I haven't used it for years, but in theory with those size tiles you could get away with a reputable brand of thin bedded ready mix bucket adhesive..leave 24 hours before grouting..
Good luck with your project. :thumbsup:
Reply to Tiling on masonry in the DIY Tiling Forum area at TilersForums.com
Dawz84
