Discuss Tiling on chipboard - why not? in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
The Legend; Phil Hobson RIP
wot about covering the floor with the orange mating from germany then tiling:mad2:
Schluter Ditra mat/ Dural CI are not suitable for overlaying chipboard. They are not designed to deal with deflection, more for lateral movement ie. screed shrinkage due to drying, crack isolation, etc.:ban:
TrumpersUnited
not for deflection it won't. Make sure chipboard is screwed down securely.
it will help if it has some kind of wax or moisture resistance substance on top though but the floor needs to be deflection free.
Bushwhacker1
looks like a few converts to backerboards from ply. For those of you that have, do you still go for the same thickness?
steveboy
Where do I get the backer boards from?? Got a floor to replace before I tile it and gona give this a bash.
Also how does it get laid on the the new floor??
White Room
topps tiles/wickes any good tile specialist store and you use flexible tile adhesive and screw it :hurray:
H
Hawkofeagles
Ok I have a floor to do but the customer is concerned about the height difference from the bathroom to the hallway. Now if I use 6mm Hardi and tile with say a 8mm thick tile what will the height difference be?
H
Hawkofeagles
What do I do as the customer does not want too much of a height difference even though I have said it's the best option??
Reply to Tiling on chipboard - why not? in the UK Tiling Forum area at TilersForums.com
laattaana
