Discuss Tiling a floor with a border and diamond in-set pattern. in the UK Tiling Forum area at TilersForums.com.
DHTiling
Basic guide to setting out and tiling a floor in a diamond set pattern with border.......
[yt]CF88vg7Mjz4&NR=1[/yt]
tiler burden
dave
when you floor tile should you always use the flat side of the trowel to spread the addy evenly into the floor then plough?
reason i ask i, i have seen some tilers just spread the addy with the serated edge. the michael byrne dvds use the flat side also..or is it one of those experience/practice things where you use the serated edge only when your good?
cheers
ed
DHTiling
Thats why i said it is a basic guide ed......i just use the toothed end of the trowel...its just as long as you get good contact with the substrate..........
grumpygrouter
Nice instructions. Why did he need to continue to make chalk lines? If the first row was correct he could work straight from that and just use the straight edge to check.
Grumpy
Thanks Dave - Do any of you guys use those monster straight edges they look great but do they seperate for transportation?
AK
Gazzer
I just about get my straight edge in my Zafira. the front is on the top of the dash and the rear is a few inches from the back window.
Reply to Tiling a floor with a border and diamond in-set pattern. in the UK Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
