Tile Trim for Limestone?
R
robthebubble
Evening all!!!!
Need some advice on installing my 12mm limestone around the window. Should I add some 12mm tile trim to make it look neater or is the general opinion with natural stone not to have the trim?
Cheers
Rob
Its personal choice rob, if you can find a trim that matches....or you can pencil edge them with router....Gaz
Just done some Limestone in Covent garden and used chrome trim but that was a commercial job. As Gaz says its personal preference.
that is totally down to your personal taste as to what is more esthetically pleasing, i personally don't like any of the plastic trims with it and i have never put chrome trims with it. i did once used a metal trim that was enameled with a colour called "soft cream jasmine" or "cream" to any normal person, it looked smart with travertine
Most table rail cutters will tilt the blade motor for mitreing, this would be my preferred method....Gaz
Take the edge off with a small mitre cut. I prefer about 1/3 of the tile width. Not using a trim means you must be very accurate, but the end result looks so much better!
If you don't have a saw which can do a consistent clean mitre / bullnose, you could always file down the edge after fixing, using a diamond file or even better a dremel with a diamond tip. (but don't slip with the Dremel!)
robthebubble,
robthebubble,
robthebubble,
robthebubble,
