Droopy
Yes, Dunlop too.And Dunlop ?
For the backerboard thickness, Dave?
That is the min' we can recommend for overboarding, so I think it must be.
Now that you have said that Dave, i am not so sure.I know that BAL recommend 10mm for floors james..but is it a BS standard or just BAL guidline for their guarantee..?
But I was under the impression that it is a BS.
And that in fact all our 'guidelines' were all based on BS's.
Though maybe Gaz or Danny could help clear this one up...
This is only a guideline for Bal guarantees, if BS changes to this as we know BS is only a guideline anyway and not a rule....GazI know that BAL recommend 10mm for floors james..but is it a BS standard or just BAL guidline for their guarantee..?
It is down to customers to seek the advise of the professional doing the job or the adhesive manufacturer. In the not too distant future cement based adhesive not enhanced with polymers will be a thing of the past..IMONow that's interesting james......because BS5385 doesn't state that you have to use an addititve( polymor) in standard or rapid setting cement based adhesives when tiling to concrete floors( un-heated etc ), but BAL now say this....
So that means that ......
1. CTF3
2. Gold star
3. Rapid set
4. Super cover
5 . ptb
all have to have AD1 added for tiling to concrete....to have BAL's guarantee.....
Now there is a difference to giving a guarantee and it bieng a BS standard...don't you think..?...
Now that BAL have added this issue to using there adhesives then i think that they need to let customers know where they stand...or do they just continue using there products as normal and with NO guarantee's....?..
1. CTF3
2. Gold star
3. Rapid set
4. Super cover
5 . ptb
Gaz, I think I might have picked up DW wrong in a conversation regarding 6mmV10mm tile backer board with this.This is only a guideline for Bal guarantees, if BS changes to this as we know BS is only a guideline anyway and not a rule....Gaz
I raised the question with Bal 2 years ago while at Topps, I didn't think 6mm Hardibacker was thick or strong enough to be structurally suitable to avoid deflection on timber flooring. Bal said they would only recommend 10mm boards with SPF back then, as a consequence I would only sell Fastflex with 6mm overlay if height was an issue with my customers...GazGaz, I think I might have picked up DW wrong in a conversation regarding 6mmV10mm tile backer board with this.
My bad.
I think here in lies the problem.
BAL have taken the technical data available on cement boards. As far as we are concerned 6mm is not strong enough.
Now other adhesive manufacturers, may say they don't have a problem with cement board of 6mm thickness.
IHO they are basically saying, 'if the cement board manufacturer is saying 6mm is OK for floors, then you can use our products'.
If you have a failure on one of these floors, the only guarantee an adhesive manufacture has to uphold, is on their adhesive.
So they'll take away a sample of their adhesive. If it meets up to their formula, they will assume (and rightly so) that the problem was something on site beyond their control. If thats 6mm cement board, then you're left to take that up with the manufacturer of the board.
Just my opinion.
