Tile Spacers and Grout lines
It is interesting this Hardie stuff. The 6mm hardie ia a denser product than the 10mm according to Hardie spec sheets and was designed specifically for floors. Whether it adds strength or not has been questioned before and as yet Hardie has not provided any definitive answer.
It would be good to get this clarified if possible.......Holahana?????
Other parts of the world, such as downunder, don't consider either 6 or 10mm cementboard (hardi etc) to add any significant strength to a floor. It's merely deemed a more stable substrate for tile than plywood. I think if you approach it with that attitude - get the subfloor up to minimum deflection standards (l/360 over there?) you'll be right.
Over here, the benchmark for floor strength is 22mm chipboard on joists with 30cm spacing. Anything weaker than that has to be reinforced before recieving tiles, and that's either done with a minimum of 12mm SLC reinforced with 2.5mm rebar netting, or through gluing 12mm fibercementboards or floor grade plasterboards (alot denser, heavier, and more rigid than regular ones) with cement based adhesive, specifically C2F/S1-S2 type adhesive.
hello...friend...
just want to ask u all, what type of product for tile joint is waterproof???
white cement is just not good...
My problem is my bathroom water is leaking to the unit of lower unit.
i need it desprately. pls recommend...:thumbsup:
hello...friend...
Epoxy grout is waterproof, but if you have a leak, you need to be very sure it is just the grout joints causing the problem. If your grout has cracked and leaking why has it cracked? Just replacing the current grout with epoxy stuff may not actually solve the problem.
hello grumpygrouter.
Thanks for ur reply...
Actually i am doing waterproofing job here.
I do pu grouting all the times.
After searching for better product ex. kiss polymer..it can waterproof concrete.
As u know, the tiles spacer if it just replace the white cement it would not last long.
I m searching for , as u said epoxy grout..
Example..bathroom floor trap leaking, i can use the kiss polymer , apply it to the concrete and all the things i need to do.
But for the grout lines, i need ur help..
Where can i get the epoxy grout??
i m In Malaysia..
Tq in advance:8::mad2::thumbsup::thumbsup::thumbsup:
Hi TQ, I am afraid I really don't know what to suggest about finding epoxy grout. Maybe if you check out [DLMURL="http://www.ardex.com"]Ardex Global Loading...[/DLMURL] you may find somewhere in your country that supplies it. They make an epoxy grout but I have never used it.
Hiya kok123 here are the details of mapei in malyasia..they will be able to tell you who stocks mapei kerapoxy in malaysia.....
good luck..
Mapei Sdn. Bhd (Malaysia) PT 521, Batu 23 - Jalan Ravang Jalan Batang Berjuntai - 48000 Rawang - Selangor Darul Ehsan - Malaysia Phone +60-3-60935799 Fax +60-3-60915801 [email protected]
thanks dave.:hurray:
will contact the supplier. :hurray::hurray::hurray::hurray::hurray::hurray::hurray::hurray::hurray:
million tq to all.:thumbsup:
Proper Job,
kok123,
Proper Job,
kok123,
