Discuss Tech Info required in the Canada Tile Advice area at TilersForums.com.
On one
Apologies for the scant information that I have at the moment,but I need a bit of technical information before going to have a site visit with a customer tomorrow morning.
The customer has an kitchen floor which is half concrete and the other half will be a suspended timber joist/chipboard floor(when completed)
Obviously the chipboard will have to be overboarded and an expansion joint placed over the different substrate joint,but should I overboard the whole kitchen floor(is it possible to drill,plug and screw Hardi into concrete?)
The tiles are going to be 20mm multi sized Limestone
Alan.P
1,058
Stockton-on-Tees
Yes you can fit Hardi to concrete, why don't you factor in for Plywood instead of chipboard and add hardi over the lot ? Allow for an expansion joint where the two meet, how big is the floor.
White Room
Screwing Hardie to the screed floor is not somethink I've tried, what about self leveling....
Andy Tiler
1,043
manchester
Can't see y not? But if it were me I'd screed up the concrete side with Tilemaster levelflex! It's ready for tiling after a couple of hours!!
On one
Not sure, not seen it yet.
C
charlie1
As for the 20 mm multi sized limestone, I assume the expansion joint wont be straight forward??
On one
Can't see y not? But if it were me I'd screed up the concrete side with Tilemaster levelflex! It's ready for tiling after a couple of hours!! 
Don't know if the existing concrete floor needs SLC yet. My main query was do I need to bridge the different substrates with Hardi or can I overboard the chipboard floor and butt the Hardi up against the concrete floor with the expansion joint over the top?
Andy Tiler
1,043
manchester
Yes butt the hardi up to the concrete and put your joint on top! Don't bridge it!!
Reply to Tech Info required in the Canada Tile Advice area at TilersForums.com
