Discuss Sockets on split face tiles in the Canada Tile Advice area at TilersForums.com.
Dumbo
Thank you, I'm going to be purchasing a new grinder and blades, I was going to go with the Bosch variable speed grinder and these blades. Are these blades ok or would you get other blades for the grinding/sinking cuts?
Be aware when you run a grinder at lower speeds you get more torque hence the blade may grip more and cause it to catch and then you may skid the blade over the tile . I don't know the science but Jeremy Clarkson could explain it but i dont think he is an active member
dg-1984
288
Glasgow
So do you think a normal grinder would suit for DIY then, or get the variable speed so can do everything with the same tool.
Dumbo
You only really need a variable speed grinder for doing things like polishing with diamond or carborundum discs .
I have also used mine for slowing down a core drill and floor grinding .
widler
1,328
England
I do don’t think it will be too hard, just be patient, slso with being porcelain and not natural , they won’t be to bad to keep clean compared to stone splitface
MalcyB
98
Lincoln
I put a spacer behind the socket/ FCU and cut the tile to that.
Like this.
dg-1984
288
Glasgow
Like this.
Like this.
Thanks for that, what size spacer did you use?
Did you grout between all the tiles? Just asking as I head ready some people hadn't grouted the tiles and just butted them close together.
Also wondered if you found it hard to grout due to different heights and textured face of the tiles?
Thanks.
Reply to Sockets on split face tiles in the Canada Tile Advice area at TilersForums.com
