miksto
I'm installing a shower cubicle in a room with a woodchip papered ceiling. My intuition tells me that this is not a good combination and I'm not sure what to do about it. Would I get away with painting it with an appropriate paint (eggshell or something similar)?
I'm reluctant to remove the paper because it's in a very old period property and I'm not sure what I would find underneath and how much damage I might do in the process. There are various lumps and bumps in the ceiling which I guess the woodchip paper was designed to conceal.
Alternatively I was thinking of perhaps attaching a small panel to the ceiling directly above the cubicle itself (of wood or backer board) and either painting it or tiling it with mosaic tiles (as I plan to do in the cubicle itself). I'm assuming I'll be able to attach it by screwing through the existing plasterboard into the joists above providing I can locate them. But I'm concerned that moisture might get trapped between the panel and the ceiling and cause problems with mould and decay. Is a ceiling panel a viable option and if so what would be the best way to approach it?... tile adhesive or something similar to avoid any gaps between panel and ceiling?... How easy would it be to tile with mosaic tiles? I've never tiled anything before let alone a ceiling?
Would be very grateful for any suggestions.
Thanks,
Mike
Thanks,
Mike
