Discuss Self Levelling over old adhesive in the UK Tiling Forum area at TilersForums.com.
R
reeso
I've just knocked my toilet and bathroom into one room and discovered the 2 floors are slightly different heights.
I want to use a self levelling compound to bring the (old) toilet side up to the same level as the bathroom.
There has been some form of thin layer applied to the floor to stick the old lino onto which I have scraped away. Now I am faced with some form of old black adhesive. It isn't sticky.
What type of self levelling compound should I use?
sWe
The black adhesive is probably asphalt based. Be aware, that if old enough, it might contain asbestos. I don't know what british regulations say about that though. If it's ok to just cover it, I'd use Ardex Arditex, or something similar. Make sure to follow the manufacturer instructions of which ever product you chose.
TilingLogistics
The black stuff is probably some form of old bitumen based adhesive used years ago for marley type tiles.
Kev
sWe
I think I unintentionally wrote in american english. :stupid:
Bitumen is an asphaltene material. I forgot that in british english, "asphalt" refers to mineral aggregate and bitumen, where as in american english, the bitumen itself is often refered to as asphalt.
So if I say asphalt, I generally mean bitumen.
F
floydyboy
i cover this stuff on a daily basis and a majority of it does contain asbestos acording to the reports i receive
we us cempolatex self leveling compound,it is bonded to the floor using SBR not PVA. if a thickness is required you should add some sand to the mix to give it body. hope this helps:thumbsup:
R
reeso
Thanks everyone. I'll buy some Arditex tomorrow. I've got some BAL Prime APD already - can I put some of that down first instead of forking out for SBR??
sWe
Here's the manual :thumbsup:
Woody123
sWe
I know this is probably gonna sound stupid but when use SLC how do you know what thickness you have applied (i.e 8mm,12mm....) Do you use the square meterage that you have covered as a guideline or is there something really simple im not picking up on?:whatchutalkingabout
sWe
Four easy ways of controlling SLC thickness:
  • Stick your folding ruler into the SLC. The most obvious way, but useless if the initial substrate is uneven.
  • Mark the surrounding walls using a ruler or a tape measure, and a spirit level. Mark a bit higher up than your intended final level with a pen, and work your way around the room with the spirit level, making a line. Use that line as a guide to mark the final level with your measuring tool. Just make sure that you hold it at a steady and straight 90 degree angle. Pour up to the marks.
  • Put down some sort of level guides (nails for example), and make sure there level with you spirit level. If they're too high, just tap them down a bit.
  • Mix exactly the amount you need to get the desired thickness. If a particular SLC requires 1.7Kg powder per mm per m2, and you want to pour a 10mm layer on a surface which is 5m2, do 1.7kg x 10mm X 5m2. The result should be 85Kg. Make sure to mix in the exact amount of water stated in the specs though. Do a search for "materials calculator" on the forums, and you'll find a spreadsheet I made which you can use to calculate this.
There are other ways, but these are straight forward enough.
Reply to Self Levelling over old adhesive in the UK Tiling Forum area at TilersForums.com
