Discuss Replacing chipboard floor for tiling advise in the Australia Tiling Forum area at TilersForums.com.
Regarding the floor, I would use a decent quality ply wood (18mm) exterior grade. Wickes sell it. And then glue and screw HB onto this. Then tape the joints.
We spend our lives advising against using materials that expand and contract with atmospheric conditions or copious amounts of water, British Standards have just been amended the guidelines to eliminate ply walls , and floors are just a matter of time.
So why do we still want to fit ply and then overboard it!
That’s two processes, good quality ply (contradiction in terms) barely exists, and marine ply although the correct material is extremely rarely used.
And then you want to do it all over again by overboarding with a cement board that needs glueing, screwing and the joints taping.
And that is NO guarantee that movement cracks won’t transfer thro. It happens all too regularly.
Any gypsum structural board goes straight to joist, is primed and then tiled and has a lower profile overall.
I’m not digging you out in particular Andy (waluigi) cos it’s said all the time.
I just struggle to understand the logic behind it.
And as far as existing boards going beneath stud walls are concerned, most plunge saws will cut within 15mm of a wall, so I don’t teally see that as an excuse either.
If you’re gonna strip everything back and start again, why put the same bloody stuff back again.
It really doesn’t make sense to me.
And breath....... :)
Yes I was surprised on how little supports there, I'm going to reinforce but still can't make my mind up to go nmp or marmox
Marmox, Dukka, wedi, anything like that is a better surface than nmp.
And they only need tanking on the transitions.
(Wall to wall and wall to floor junctions) and over the mechanical fixings (screws and washers)
NMP needs tanking in its entirety.
Waluigi
Not digging me out yet you ignored Boggs’ reply suggesting chipboard is laid first and then overborded.
Why would I lay ply and overboard it? Because that’s something I’ve done before many tines and very rarely see 22mm cement boards. Maybe I’ll look into this further. Thanks for the information.
Also Boggs suggested that there might not be a joist under the stud wall if the joists run parallel with Said wall. That has nothing to do with cutting up to the stud wall. My apologies if I misunderstood why you mentioned that.
Haha Andy, honestly I was not ranting at you, you have my word.
I expect the first comment got me brooding about it.
I don’t publically berate members. (Often :D) I do it in private.
I was just being a bit expressive about my feelings on the subject. :)
I truly apologise if you felt I was being personal, I wasn’t.
And anyway if I was digging you out, I’d of said so. :D
Believe me there are many guys here that would do exactly the same as you, it just baffles me as to why.
It’s a shame you can’t get hardiefloor anymore, brilliant product.
Sorry Andy.
tony Dimartino
It does raise an interesting point though and honestly not something I had considered.
I bet if we fast forward ten years someone might be ranted at for rebuilding a room yet not replacing the timber joists with the new cement resin joists that would be available in 2028....:grimacing:
I totally agree, I last tiled 12 years ago anfdthen I put ply down sealed it and tiled, TBF it never cracked or moved in 12 years. But things have come on so much its a complete minefield !!!
P
Perfect Tiling
One thing you will need to be aware of is the weight of your tiles. No matter how many studs and dwangs you put into the wall if you go down the plasterboard route it will only take a maximum weight of 32kg.....thats for everything. Allow around 4kg for cement adhesive which you'll need as they're porcelain and that leaves 28kg for your tiles. I carry a set of bathroom scales as some of these tiles are so damn heavy. Topps regent 9mm tiles are right on the limit at 27kg a box of 6 (1.08 sq mtrs). 12mm HB 0r Marmox style boards will take well in excess of this.
Boggs
1,118
Uk
Using 6mm Hardie over new chipboard is what I would usually do, never had a problem but we all do things differently.
When I do a job I take into consideration how and what damage it might cause when it has to be removed.
22mm t&g No More Ply screwed directly to the joists is a great idea in theory but what damage might it do to joists when it has to be ripped up?
Floors are easy to replace, joists not so.
Joists under walls is a point I make from experience, if everyone cuts back the floors to the nearest 15mm without a joist under to support it the wall may well start to drop with the weight of tiles etc on it. It’s better to cut to the nearest joist inside the bathroom.
Reply to Replacing chipboard floor for tiling advise in the Australia Tiling Forum area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
