Removing efflorescence
Thank you for that halt on things !!!
Re your post :
But if you use cristallisation on floors exhibiting efflorecence you will then make your problem worse by leaving yourself open to spalling wont you ??
tiler
no not always when you cristallise the floor the wire wool pads are doing the work of the removal of the salts i have removed light efflorense by cristrallising floors and its sorted it but again it seems pointless talking about this subject as every situation is differrent to any other
As christalisation would involve the holding in of the problem due to the surface closure and could take all day to disect, i think your right it would be pointles.
tiler
I don't think Kev was talking about cristalisation. Im sure he wouldn't recomend this.
As far as Im aware, and Im no expert. When you cristalise a stone, you create a hard shiney layer on top of the stone. If you use this to remove effloresence, and the cause of the effloresence is in the substrate, then all you do is lock in the problem
You are correct on both counts I believe :thumbsup:
tiler
Bang on
The cause of the Efflorescence has to be solved otherwise its a finger in the dyke job. What is the point of getting rid of effloresence if just reoccurs?
Kev
Fact: If effloresence occurs in Natural stone and you wet grind, hone or polish it will reoccur.
Fact: You must establish the cause whether that be the DPM or anything else you need to stop the problem at source or you are wasting your time.
Effloresence can be sorted in any situation provided you deal with it in clear logical steps:thumbsup:
Kev
sWe,
Dan,
sWe,
Dan,
