Recommended cutter for 1200mm porcelain
The material you’re trying to cut could well be part of the problem.
Just because a smaller version of the tile cuts, that in no way means a larger piece will.
The only similarity will be the colour and possibly texture, other than that they are completely different tiles.
Understood. I ended up using a crappy £90 wetsaw on them in the end
Here is a vid of what I’m doing:
James that tile sounds quite textured. Try scoring it several times until you’re definitely through the glaze then gently weaken it with the breaker at the top end 15mm back from edge until you hear or see the surface begin to open but stop at that point and move back to the bar end with the handle and in a slow and gradual action apply force with the breaker and see if that works.
I scored it about 4 times, but I'' give it another go either later or tomorrow (daddy duties at the mo haha), thanks for the suggestion 🙂
And to top off my Sigma hatred, as I was getting the 'shark' (looks like a shark with the fins out) out my van, my 25kg tool rucksack fell out and straight onto my foot. I now have a damaged big toe 😡🙁
What cutter do you normally use then?
Well I’m only on job number 3, but I use this one.
James De,
Waluigi,
James De,
Waluigi,
