Discuss Preferred method of prep for chip board? in the America Tile Forum area at TilersForums.com.
Hi there,
Don't know whether it's just a matter of personal preference but what's the best method of prepping a chipboard floor?
i.e. 6mm cement boards, glued and screwed or Ditra mat? Cheers.
Paulg83
Please contribute to this thread if you have any new information or can even just reiterate what has been said already. :)
Hi there,
Cement boards, you want to ensure you have a solid base, fix any bounce or movement on your chipboard if you have any before you lay down your cement boards.
eddcottee
Ditra Mat and other anti crack mats, don't help with "bounce" in a floor. They serve another purpose.
As Paul has said above, ensure your base is solid and then overboard it with cement boards. Personally I like using Hardiebacker generally and if you type "Hardiebacker Installation Guide" into google, it will tell you what you need to know to install it.
Kevbos
Hi there,
Personally I'd make sure no bounce in floor first !! Then overboard with 22mm ply screwed at 6inch centres prime with sbr , then durabase ( decoupling membrane ) and then tile !!
Reply to Preferred method of prep for chip board? in the America Tile Forum area at TilersForums.com
Teejay
