Porcelain Tile Cutter
Hi Everyone,
Thought I'd start another thread, rather than clutter my other 2 up! Which will hopefully be useful for any other newbies looking for advice.
Looking for a porcelain tile cutter that will cut the majority of tiles (approx. 600mm x 300mm x 10mm).
I appreciate I may need a wet cutter for some of the cuts (will hopefully be able to borrow one), but will this suffice for cutting the majority of my tiles:
Vitrex 102360TC 10 2360 50cm Heavy-Duty Tile Cutter: Amazon.co.uk: DIY & Tools - https://www.amazon.co.uk/d/Hand-Cutters/Vitrex-102360TC-2360-50cm-Heavy-Duty-Tile-Cutter/B002SH62KK/ref=sr_1_3?ie=UTF8&qid=1493284454&sr=8-3&keywords=tile+cutter
I don't need a super duper cutter, just one that works well.
Thanks in advance.
As an Amazon Associate we earn from qualifying purchases.
Probably your best bet is to ask the tile shop you got tiles from if they have a cutter they lend or hire out . If they do it would probably be a rubi or sigma . Most independents do this around my way
It looks like we're going to be buying online.
I don't want to spend a lot of money, but it needs to get the job done.
The reviews for the above look okay, but I thought I'd check with the experts🙂
Hi Everyone,
Thanks in advance.
With that, cut only the potatoes. But I, just an apprentice 😉
Can you recommend a tile cutter that will do the job that I require, i.e. Cut 600 x 300mm tiles?
Ideally I don't want to spend loads, as it will get very little use after this job.
Would an option be to hire a cutter for a day and aim to get all the cuts done in one day (don't know if this is feasible)
I know of only one place in my area that hires out a cutter - a Rubi 1200. If you don't want to spend around £300 on a Sigma, a Big Clinker is a cheap alternative. Although not the most accurate it's perfectly adequate for your average tiling job.
Shooter999,
Tmk Tiling,
Shooter999,
Tmk Tiling,
