• Thread starter Tiberius
  • Start date
  • Replies 22
  • Views 9K
  • usa
Discuss New rotozip! in the UK Tiling Forum area at TilersForums.com.
1,098
Somerset
I have both Rotozip and Porsadrill bits. For cutting clean holes for pipes the Porsadrill is first class. For cutting those nasty odd curves (e.g. if you cut around toilet and sink plinth bases) the Rotozip is the tool to use. Both tool bits require care to get the best out of them. I burnt out my Porsadrill 16mm bit cutting through a hard floor tile - my fault probably for drilling too fast! The Rotozip bits are prone to breakage if you dont take care to drill in a sawing motion. Either way - not following the manufacturers guides is expensive!
Deleted member 1779
Nice bit of Feedback Andy. Send me by PM your address and we will send out a replacement 16mm as goodwill.
It might not arrive quickly because we are blocked out this week at the Gadget Show in Birmingham NEC.
I guess the message is really to read the instructions. With our kit the three golden rules are not to press too hard, to use some water and finally to drill slowly. That gets you the maximum lifespan per diamond core and holesaw. The main point is to keep the heat out of the core bit.
All drilling is a wear and tare exercise but the steps you take to keep them cool will prolong the lifespan.
mikethetile
Ive had a rotozip for a few years now , its one of the first bosch ones
handy bit of kit but bits pricey
I agree with stan, if you want it for drilling holes use a drill it will last longer
I use mine as a mini router and for freehand trimming work
Deleted member 1779
Oh yes I can see from the packaging that its all black and scorched....
You did use Evian pure spring bottled water I hope. Unless you use premium bottled water they wont work. Dont ever try tap water !!! :lol:
Failing that a bottle of white wine... (Dont use red wine to cool them only white wine works) :lol:
mikethetile
would homemade rhubarb wine circa 04 do the job richard
im asking as everyone refuses to drink it
it tastes allright, nice and smooth with a hint of rhubarb but it has a funny effect on their speech and legs
would this be a suitable lubricant
Deleted member 1779
couldnt get my badboy code to work so didnt get the 115 mm bit
Thats because the discount code is not Badboy..... ITS BIGBOY !!!!
If you use Bigboy as a discount code (and providing you have a bathroom fitters in the basket) then there is an automatic half price deal on the 115mm dropping from £59.99 to £29.99
DISCOUNT PROMO CODE: BIGBOY
Reply to New rotozip! in the UK Tiling Forum area at TilersForums.com
  • Poll
