Guest viewing is limited
mosaic
shogun rua
Hi,
Im doing a small wall with glass mosiac on tuesday 2sqm by 2sqm roughly, the wall isnt too true,
How would you rectify it? Bearing in mind im starting on tuesday?
Cheers
Paul
Quickest and cheapest way would be to replace I'd say, only a couple of boards and some drywall adhesive. ( I'm assuming it's dot and dabbed plasterboard not a stud wall)
Sent via Tapatalk for iPhone
No its a stud wall, the only thing with replacing it is, ive tiled up to the
wall on both sides, then the sprung the mosiac wall on me lol
hi Kilty,
It dips in about 20mm in the middle probaby off in the top corners aswell.
Cheers
Paul
yes mate ive used it a few times....think it sets solid in 2 hours
has decent body to it,just check its ok for plasterboard but i have no doubt it will be
As above, if you cant replace the boards or get over it whilst tiling then I would use a rapid setting cement to sort it :thumbsup:
i would overboard, it would give you a perfect flat finish for the mosaics. i don't understand why you can't
mosaic
shogun rua,
Mike,
shogun rua,
Mike,
