Discuss Mapeii does not reccomend on Ditra ! in the Canada Tile Advice area at TilersForums.com.
would a polymer modified adhesive be your avarage porcelain adhesiveI'm not a huge fan of Ditra matting. My distrust of this product though stems back 20 years when it was completely and entirely misunderstood.
Shops were selling it as some form of super replacements for all sorts of solid substrate suggesting you could use this stuff to tile straight on floorboards, floating floors the lot. I had to correct so many failures.
So rather than become misinformed I spent a long time on the phone (at the time) with Schluter technical. Fortunately now much of this information is available in easy downloads - here's a great info sheet:-
http://www.schluter.com/media/DITRAHandbook-ENG-2013.pdf?v=201306080603
If you look through you will see without exception that the tile is fitted over the Ditra with unmodified thin set mortar. That means no polymer additives at all to comply with the correct installation guides of Schluter.
Things have developed a lot since I stopped fixing but certain constants remains, if I understand this correctly, once you used a polymer modified adhesive on top of Ditra matting the uncoupling mechanism ceases to work or is reduced in efficacy substantially. In so much as it's no longer truly operating as a decoupling membrane.
How does this then dovetail with the BS standards requiring polymer modified adhesives to be used in these situations particularly with UFH?
Schluter UK and Schluter USA give quite different advice which is odd. Modified in the UK and unmodified in America if I recall correctly.
so stiking porcs to ditra witch make up most floor tiles cant be guarenteed by dirta if i am understanding this right ?
its a shame they change at our cost usaly untill the real answers are found by us through trail and errorHere is Schluters explanation of how Ditra works:-
Uncoupling Membranes - Uncoupling Theory Part 2 - Schlüter-Systems
Here's the UK spec sheet:-
Broken Link Removed
On page 5 of that document it states:-
6.Immediately after the Schlüter®-DITRA 25
matting is installed, the tiles can be set
using the thin-bed method and using a
bonding tile adhesive that matches the
requirements of the covering.
So it doesn't state if polymer modified is or isn't an issue.
It's interesting how there seem to be different specs between UK and USA as Peter mentioned earlier.
It would be very interesting to hear Schluters clarification of this - it used to be big no no (polymer modified) when I fitted Ditra, but things change.
Schluter have always said unmodified in the spec sheet, but how can that effect the uncoupling characteristics of Ditra? I'm no rocket scientist but that makes no sense.
The explanation provided by Schluter (at the time) was that the extra polymers in modified adhesive "tack" the adhesive to the Ditra and reduce or negate the uncoupling mechanism.
I saw failure after failure with this product back in the day, I saw so many I never used it again. Since this time though the specs and design of the product seem to have changed.
I read a lot on this (and other) forums about people using this product in all sorts of situations in which it appears not to really be necessary. Quite honestly it looks like it's become the emperors new clothes.
Ditra is a totally different product from what it was 20 years ago Alan when it had hessian backing and had channels instead of dovetailed dimples, part of the problem back then was it was mis-sold as a magic carpet solution for floors with unsuitable substrates i saw many failures at that time too but now I am a believer and think it is a good product when used correctly, it is overly specified at times and some builders still believe it to be the magic carpet solution to badly prepared substratesThe explanation provided by Schluter (at the time) was that the extra polymers in modified adhesive "tack" the adhesive to the Ditra and reduce or negate the uncoupling mechanism.
Reply to Mapeii does not reccomend on Ditra ! in the Canada Tile Advice area at TilersForums.com
