Discuss Manual tile cutter in the UK Tiling Forum area at TilersForums.com.
R
ross lewiss
just reading some reviews on what cutter to get and rubi seem popular but how do you cope when you cannot cut corner to corner on a thick piece pf porcelain. would you need another cutter? hope i have made sense?
thanks, ross
Daz
Hi Ross,
I use a Rubi TR600-S for straight cuts. The only thing I have struggled to get a good straight cut on is fully vitrified tiles, only my wet cutter will go through those suckers.
For internal corners or shapes I use a combination of wet cutter and nippers (ceramic only for nippers).
Hope this helps,
Regards
R
ross lewiss
so if i buy a ts70 plus and i need to cut a piece of tile that the breaker wont cut due to the fixed breaker, then i have to use a wet saw? more expense arrgh
i only want to concentrate on ceramic and porcelain because i cant afford to buy all the equipment for the other kind of tiling and i thought a rubi tile cutter would cut any porcelain or so the video clip shows?
H
Holohana
Then its the Tx or TR range of rubi your after, moveable breaker.
Daz
My TR600-S doesn't have a fixed breaker so I can make straight cuts anywhere on a tile. Within reason, as it doesn't play nicely when trying to just take a small amount off! But no dry cutter will allow you to do internal corners or shapes unless you want to score with a dry cutter and then nip the sucker out (horrible if trying to do it with porcelain or vitrified!).
R
ross lewiss
its says you can do curved cuts on the rubi cutters. how do you do that when the rail is straight?
sWe
I've tried Rubi cutters, but I didn't really like them. I used Sigmas until fairly recently, when I switched to Montolit, which in my opinion are among the best cutters you can get.
Without really trying, I can cut slivers just a little over 1cm wide, out of 10mm thick 33x33cm (larger than that is rare over here) Porcellanato, which is the densest, hardest grade of porcelain.
R
ross lewiss
thanks swe
i am gonna look at montolit. rubi seem to be really big but theres too much choice??? i realise that i wont be able to get away with just one cutter but montolit and sigma and husqvarna seem to narrow the choice down so it makes it easier for a lamen like me. what 2 montolites would you suggest. when i finish my course i will concentrate on kitchens and bathroom and small floors.
thanks, ross
R
ross lewiss
if one of the guys who use montolit could take a look at the web site mentioned above kwiksplit.co.uk and have a look at their tile cutters and maybe recommend 2 cutters then that would be a great help. i think the 63cm would be the max i would go to/
sWe
First you need to decide wether you want a push or a pull cutter. In my experience, pull cutters are faster to work with, but push cutters are easier on the wrist.
My old main cutter was a pull-Sigma, and part of the reason I switched cutter was that it was a bit hard on the wrist. I also wanted something different.
So I went and bought myself a Montolit MasterPiuma 63P2. It covers 90% of my cutting needs. Next time I get a job with lots of small tiles though, I'll get myself a MiniPiuma PB, as the MasterPiuma is a bit bulky and heavy.
R
ross lewiss
http://www.youtube.com/watch?v=yigAjKmquIY
just found this on youtube and it shows the sigma you mentioned, couldnt find one on montolit but loads about rubi. your right, the pull motion looks the most natural although some people on here say they are difficult to get used to. its a minefield for a learner arrrgh
sWe
Videos of Montolit's main cutters:
MasterPiuma P2
MasterPiuma T2
MiniPiuma PB
MiniPiuma TB
The pull motion has a more pronounced feeling of control than the push motion imho, but I've used pull cutters for most of the time I've been a tiler, so it's probably just that I'm still more used to pull cutters than I am to push cutters.
The push motion is more ergonomical than the pull motion, as you don't have to twist you wrist.
It's mostly a matter of what you're used to.
R
ross lewiss
thanks very much for the video clips swe, thats made the choice alot easier for me. i was swayed by rubi because most people on here use them but i just like the look of the italian cutters.
many thanks, ross
Reply to Manual tile cutter in the UK Tiling Forum area at TilersForums.com
