UK Pro Tiling Training
This official sponsor may provide discounts for members
Electric UFH loose wire UFH...
Discuss loose wire UFH... in the Tiling over Electric Underfloor Heating area at TilersForums.com
Mapei Tile Adhesive - Official forum sponsor
Andy Allen
Reactions
18,373 184
Gloucester
I've got a job coming up where the customers electrician is fitting a loose wire system, he's using a tape under the wire which he says is as good as insulation boards, not to sure about that, but my biggest concern is will I be able to level over it and tile it without the fear of a failure due to this tape method he's using, anyone ever seen this before??
Uheat - Jake
TF Official Sponsor
Reactions
146 1
What type of tape is it? We recommend to use a fireglass mesh tape with our insulation boards.
Deleted member 38091
Reactions
4,662 58 1
Salisbury
What member type are you?
Professional Wall and Floor Tiler
If it does insulate it's only going to insulated under the tape . So where ever their isn't tape you are going to get cold bridging between slab and tiles . As for the tape to latex over it's got to be super sticky as there is next to no contact area .
Andy Allen
Reactions
18,373 184
Gloucester
  • Thread Starter Thread Starter
  • #5
it's the tape underneath the wire I'm concerned about, he says it some kind of insulation tape, to take the place of insulation boards, have you ever heard of such a thing??
Post automatically merged:
The electrician sounds like an idiot
I have to agree there, but this is what happens when a customer doesn't want to fork out on insulation boards, and talks to Mr know it all electrician...
Dan
Admin
Staff member
Reactions
5,834 31
Staffordshire, UK
DIY Wall and Floor Tiler
Totally sounds like a blag. It's so the electrician can be in and out in half a day and still charge 250 labour lol
I've just fell out with one on sparky forum who was trying to put off a DIY from asking about running a cable to a shower. In the end it turned out he was worried about losing money. He said he's on 500 a day.
Reactions
77
Cornwall
Have fitted a fair few heat mats and wires over the years have used that primer once in the past (looked like something you would drink to settle a stomach ulcer!) Was a waste of time. Cant see any liquid insulating primer being effective as the final coat will only be a fraction of a millimetre thin. Don't believe the electrician on the insulating tape being used under the wire either. Even if it did stop heat loss under the wire the remaining areas would still loose heat. Only proven and tested method is the insulated tile backer boards.
Reactions
4,662 58 1
Salisbury
I agree, as I said earlier it will not stop cold bridging in areas that don't have tape.
Anyway I always thought electricians insulation tape was to insulate against electricity, are you sure he's an electrician
Andy Allen
Reactions
18,373 184
Gloucester
  • #11
I've tried telling the customer all this, but at the end of the day that's all we can do, if he wants to go down the electricians route then that's up to him, all I'm interested in is whether or not it's suitable to tile too.
Deleted member 5970
Reactions
8,514 63 3
on a yacht somewhere on the essex coast
Andy, until you know exactly what he is proposing to put down you can't ask your adhesive supplier if they do a product suitable to fix to it. They well do but it may cost an arm and a leg
Reply to loose wire UFH... in the Tiling over Electric Underfloor Heating area at TilersForums.com
uHeat Official Forum Sponsor for Underfloor Heating (Electric and Wet)
New Threads (Sitewide)
Top Bottom
I've Disabled AdBlock
No Thanks
Use TilersForums.com to find Tiling Jobs or your Local Tilers for free. Get tiling tools at the best prices via the forum.
