Minnie
Hello again
Could anyone tell me if it's a strict no-no to cut tiles at the top?
Here's a picture of the wall I'm doing.
DSCF0448.JPG - DivShare
From the bath to the bottom of the splashback on the sink is 25cm. The little splashback is 6cm and from the shelf on top of the splashback to the bottom of the window sill is 40/41cm.
I had wanted to go up to the bottom of the window sill rather than have it the same as it is in that picture (ie. differing heights of tiles above the bath and sink). However, whichever size tiles I use, I can't think how I'm going to line up the grout line of the main wall tiles with the grout line of the splashback on the sink.
Using 25cm tall tiles would take me to the bottom of the splashback on the sink, but then I'd be left with 40cm above it and I had wanted to put a 5cm border at the top.
I've tried figuring it out with all different sized tiles but keep getting stuck.
I'm figuring I either have to maybe fall 10cm short of the window sill or ignore the grout lines in the sink altogether.
I had looked at getting 40cm tiles and cutting them down, but figured there'd be too much wastage. Was going to go for 25x20cm as they were easier to handle and less weight etc. but I can't figure out what to do with lining sink up etc. Any suggestions welcome.
