White Room
Overall are you just tiling to the window cill
You will have to do a gauging stick with the new tiles and measure down from your window cill to find if the tiles will sit right and follow thru above your sink. Try to keep the grout lines level to the sink but include the border. Do a picture of what you trying acheive then it willl be easier to understand, you have so many elements to this job it seems more complicated than it probably is
If you have cut the top tiles to the window cill and follow round you can buy plastic trim to hide the cut on the tile around the bathroom, no problem.
What's wrong with tiling above the window sill, by doing this and then tiling the sill and a small upstand on the reveals would make a much better job and would probably eliminate the problem above the sink.
