Waluigi
How could a tile fall off no matter what clip is used?
Discuss Levelling systems & when to use them in the Canada Tile Advice area at TilersForums.com.
I’ve no idea, but when I looked at the back of the tile there was hardly any contact with the adhesive. Ain’t like I used a different trowel depth so why would only 3 tiles not contact but all others are fine?How could a tile fall off no matter what clip is used?
Weber standard set normal, 400 x 150.. no didn’t back butter/trowel them.Did you back butter the tiles? Or back trowel them? What size tiles are we talking? Which adhesive?
Wasn’t taught to do that in the course.. :/ will do that going forwardI back butter everything.
Thats your problem, also too small a notched trowel, wouldn't use less than 10mm with clips..Weber standard set normal, 400 x 150.. no didn’t back butter/trowel them.
Reply to Levelling systems & when to use them in the Canada Tile Advice area at TilersForums.com
