Discuss Levelling systems & when to use them in the Canada Tile Advice area at TilersForums.com.
Spare Tool
Should take a bit more force than a little chunk of plastic to pull a tile off a wall, are you using a suitable size trowel and back skimming the tiles?
James De
588
London
How could they fall off with a solid bed?
Have you got a pic of the levelling system you used?
And the bases are thicker plastic so you have to hit them harder with the mallet..
James De
588
London
How could a tile fall off no matter what clip is used?
I’ve no idea, but when I looked at the back of the tile there was hardly any contact with the adhesive. Ain’t like I used a different trowel depth so why would only 3 tiles not contact but all others are fine?
Waluigi
Did you back butter the tiles? Or back trowel them? What size tiles are we talking? Which adhesive?
Waluigi
........apart from mosaics :D
I’m sure we had the conversation about back buttering. What about the 120 x 60 tiles you installed?
Reply to Levelling systems & when to use them in the Canada Tile Advice area at TilersForums.com
