Currently reading:
HELP! I need to cut a 73mm diameter hole in stone floor tiles
Discuss HELP! I need to cut a 73mm diameter hole in stone floor tiles in the Australia Tiling Forum area at TilersForums.com.
L
LloydinCroatia
Hi folks
I am at my wits end, so I hope one of you chaps can help. :mad2:
My wife and I recently forked out on some really nice, large 1cm-thick stone floor tiles, not knowing how hard they are to cut.
After spending all afternoon with my hand drill and a 73mm diamond bit, which has left me with a cracked tile and only the mildest circular indentation resembling a coffee stain, I am beginning to wonder whether these damned things are impervious to everything.
Does anyone have any tips on how to make a circular cut? I have heard you need water, and I was using water intermittently but I'm at a loss as to how I drill AND poor water constantly. Straying in the drill bit while drilling is also an issue.
My instincts are telling me I am woefully under-equipped to do anything with the materials I have bought. I hope that's not true, and I'm desperate for any tips that will make things easier. My wife and I NEED this bathroom finished as we have a newborn and we can't share the inlaws' bathroom (downstairs) forever.
Thanks in advance!
Lloyd
PS - I had some pics to upload but I don't seem to have the relevant permissions.
Hi and welcome Lloyd, you could make a guide from timber to stop the straying of the bit, as for keeping water at the cutting end, break some sponge off and push it up the inside of the core bit, keep on dipping into a bucket of water whilst drilling, if that fails try an angle grinder, working from the back of the tile cut though the circle you need and chip away from the front, if you follow me.
HTH
Perry
HTH
Stop giving my secrets away you :smilewinkgrin:
Spud
Well here is a tip for a decent water flow,to keep the bit cool,
get a empty 2ltr plastic water bottle and screw a small screw 10 mm from the bottom fill the bottle with water and screw the cap back on set your drill up over the hole using a template hole cut from ply or another piece of tile undo the screw at the bottom and unscrew the cap you will get a nice steady stream of water to keep the drill bit cool if you need to slow the flow down screw the cap back on slightly and this slows the air pressure pushing the water out too quickly
Hi Lloyd.
One thing I do for a cold water feed is using a tile hole cutting guide and just removing a section of the guide but still utilising the water pump (pictured)
Reply to HELP! I need to cut a 73mm diameter hole in stone floor tiles in the Australia Tiling Forum area at TilersForums.com
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
