Discuss Hello everyone! quick question to get me started in the The Welcome Forum area at TilersForums.com.
mr white
Hi all,
Just wanted to say hello, and introduce myself :)
I'm Mick, recently got into developing property, I got experience in many trades and now I want to try my hand at tiling, so I'm here to learn and chip into the knowledge pool!
Ok I have a first question for you Pro's ;)
Do you need to use ditra mat on a concrete floor that has no cracks but has recently had hot&cold pipes chased into the floor and filled with concrete?
I would be concerned that the use of the taps could cause the area to move slightly and produce a crack.
I'll be laying, porcelain wood effect plank tiles, most probably Keraflex Maxi S1 (white)
Cheers!
Albert
1,253
Gateshead NE8, UK
Hi all,
You can just go ahead and tile it as long as the new concrete has dried. You can put down a crack mat if you want you won't harm it
mr white
Hi all, thanks for your responses!
I've clean the floor up, and the concrete does have a crack going through (about 2/3mm) I think it was due to old pipes being moved. Would I be correct in thinking that because the floor is not new, there should be a minimal chance that there will be movement? Also is there a particular product (decouple) that will do the job? I'm tiling the bathroom after this job which will be on ply wood so could I use ditra mat to go over the crack/pipes area?
mr white
Also..... (so for all the questions) My dining room floor is going to be sanded floor boards, and I want the tiles to be inline with the boards, Would I be best to lay my first tiles where the tile meets the floor board? Or should I start from the middle of the room? Mick
Reply to Hello everyone! quick question to get me started in the The Welcome Forum area at TilersForums.com
