Discuss Have I bought the wrong size trim? in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Is that the same if using an 8mm square notch trowel leaving a bed thickness of 4mm behind the tile then?Providing the walls flat the adhesive will 'bed in' leaving a very minimal gap 1 to 2 mm, which the trim flange will take up most of that, finish with decorator chaulk if painting above, or the other side of a flat wall.....job done..!
The thickness behind the tile will be minimal, 1mm at most, providing the walls are flat..Is that the same if using an 8mm square notch trowel leaving a bed thickness of 4mm behind the tile then?
Reply to Have I bought the wrong size trim? in the DIY Tiling Forum area at TilersForums.com
