Discuss Grout cracking in the UK Tiling Forum area at TilersForums.com.
N
Nightowl
HI
ring shank nails of the right depth every 4" and a flex adhesive If there is a lot of flex in the floor (bounce) use bal flex adhesive as it is very good at sorting out a problem floor for good
(but expensive)
Perry
HI
(but expensive)
and flexible tiles ? :santa_cheesy:
L
LM Ceramics
got to be the exisisting floor underneath i use to use 6mm ply before i discovered this forums and a couple of bathroom floors i did had call backs of grout cracking have used 12mm or 9mm screwed down properly never any problems
another common grout failure is bad mixing of the grout when we were apprentices we were shown correctly how to mix grout some of the apprentices at my old firm after a year couldnt mix properly lump and all sorts
medlar
i am assuming that seeing as it is the repaired area that is cracking,and that was the original reason for the repair (grout cracking away),that the floor is at fault,not the ply you used.
Seems logical that if the original floor,then the repaired floor both reacted in the same way,and in the same places it has to be an underlying fault (no pun intended) with the original floor
N
Nightowl
ooops sorry i think i posted that in the wrong place lol
But i am new on here hehehe :santa_cheesy:
Reply to Grout cracking in the UK Tiling Forum area at TilersForums.com
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
  • Sticky
