Currently reading:
Granfix floor grout?
Discuss Granfix floor grout? in the UK Tiling Forum area at TilersForums.com.
oldgit
granfix flex grout is one of the worst on the market.
you will never get a good finish ie:flush joint.
one method i used to use was to grout fairly wet,wash down hard which will take the joint down a couple of mm leave for an hour or so then regrout in the normal way.
i once took a chance with there sandstone which is even crappier than the grey,i grout some large square shouldered porc in a cold extension it would not firm up but would set rock on the surface,at 7 pm i took a gamble and dry rubbed it and as it turned out was perfect,many grout would patch when using this old method but on this occasion was fine.
i must strees that i only used this crap because i was doing a fair amount of work via a tiling outlet,they have now dropped granfix for mapei.
Reply to Granfix floor grout? in the UK Tiling Forum area at TilersForums.com
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Sticky
