Garage floor
C
cjones
hello all just need a little advice.
Am going to tile a standard domestic garage floor . Substrate is a solid concrete base with no movement.
Client is quite concerned about how thick a tile they have to get. They are looking at different porcelains but want to keep costs down as it is only a garage floor.
So...
Does thickness of tile really matter if it layed properly?
Im considering laying Ditra , is this really neccessary baring in mind keeping costs down>?
Cheers
Why is your customer asking you to tile the garage floor? is this part of a renovation project? what is the customer intending to use the garage floor for?
I have visions that you'll be laying a beautiful floor for them to park their car on!
its in a high end refurb, so have gone to town on the rest of the house, so having a standard concrete floor to park their car on is just not good enough.
Oh my! That is flash!
Something tells me you'll be looking at materials designed for car showrooms and I bet that won't be cheap... I'm sure one of the guys on here was doing a car showroom job last year so its worth looking out for the replies cjones!
GRR :driving:
I can't see why standard cement based adhesive with a trowel giving 100% coverage wouldn't be just fine, as for the tiles, I can't see why thickness would be an issue if laid correctly.
There are many porcelain tiles only 6mm thick that would do the job just fine, providing they have been bedded correctly with correct adhesive. Johnson's do a non slip range that would be more than adequate !
Does the garage floor have a DPM....?
As for the tiles and adhesive....rapid set is fine and porcelain bodied tiles are great for this type of project...
Cheers boys, i thought any tile would be alright, i think it was the guy in the tile shop trying to get the client to buy a thicker more exspensive porcelain by scaring her.
Dave i dont know about the DPM .it is a sound concrete base which has been there for years.
Thanks once again
Porcelain for sure,good 10-12mm strong ones with solid bed undertile to withtake the weight of 2 big rangerovers!!!!!
If you are not sure about the DPM then i would install a vapour equalisation membrane just in case..
Garage floor
cjones,
Bling Tiling,
cjones,
Bling Tiling,
