Discuss Found myself back at the tiling! in the Canada Tile Advice area at TilersForums.com.
Andy Allen
1,318
Gloucester
Not even the most experienced tilers on here would use rapid set in a bathroom.
I certainly wouldn't, you would be throwing more away than you use, and gives you no time to make adjustments.
P
Perry
Yes as you dont sound competent. And you may find yourself in trouble later down the line. I do not wish that with any tradesman. Even a chippy. But if you go ahead listen to everyone who's trying to help.
G
Gavin Robinson
Sounding not competent when considering a job beyond my normal range is,I would have thought,a sign of competence and hence why I seek advice from professional tilers such as your good self.Even a chippy is prepared to listen to everyone with more experience in these matters!
Reply to Found myself back at the tiling! in the Canada Tile Advice area at TilersForums.com
  • Poll
