Forming falls into wet room drain.
On one
What is the best way to form the falls on flat concrete floor in a wet room?
I had thought of trying to form the falls with adhesive,but this could be tricky trying to reach the far corners of the room over wet adhesive.
Is laying a preformed Wedi type shower former realistic/feasible considering the already cast in situ position of the drain?
Your thoughts Ladies and Gentlemen......
any pics would help, usually the drain would be at a height form the floor so you could screed the floor with sand and cement ,creating falls to the drain
This job is a new build and the whole house floor slab(with UFH)is completely flat and in 1 pour without any expansion joints!
Using sand and cement would create a very large step into the wet room I'm afraid. Even using adh or a preformed tray will create a step,but not as large.
The only way to do it right would to cut out the concrete ,adjust the drain and fit the former,lot of work I know.
That's how I'd do it and have done several wetrooms like this....2x1" wood cut with falls in, rapidset inbetween wood, thin slc then tile
In other words the walk in shower was an after thought ?
I'd do it with S&C myself which would create a step but then the architect should have thought of that tbh.
I wouldn't risk going down some thinner route for fear of break up.
Sounds like tray or step to me.
Diggy
Diggy
What exactly is likely to break up going from say 20-30mm drop to drain using flexi rapidest n leveler, you lost me there..
Have done it this way for tiling on and vinyl floor and water goes exactly where it should...straight down the drain :thumbsup:
Diggy
When I first went to look at the job I told the customer non slip vinyl would perfect for the job,even doing myself out of the tiling work. And I left the customer thinking that was what they were going to do, but they have been back on the phone wanting a price for tiling.
Yep always left the wood in its only 2x1 scant and only a guide for forming the falls..
I've a wood yard near me that I can take the drawings in and they'll cut the wood to order for a fiver tip...:smilewinkgrin:
On one,
Spare Tool,
On one,
Spare Tool,
