First attempt at a envelope cut into a linear drain
Wayne Brown
Hi guys what's the best way to finish off this and get the tiles back into bond ? Cheers w
The envelopes should be cut out of the bond you already have on the main floor, looks like you've got a 100mm cut running down rh side, this should be followed through to the tray, is it all stuck down or could you rethink the whole floor set out?
Can't see much evidence of tanking around the wet area?
I have not stuck em all yet this is as far as I have got alot of work gone into the floor so want it looking good I am a trusted advisor on the ukplumbing forum been on there for a good few years but got directed to you guys for a bit of proffesional advice regarding this cheers Wayne (aka kop)
20181130_170926.jpg 20181127_110740.jpg 20181130_170936.jpg IMG-20181127-WA0000.jpeg IMG-20181128-WA0008.jpeg 20181129_090133.jpg
Sorry guys still there i didn't flood that area slopes are still there you can see em on the marked out picture confident on the tiling just need to get back to the bond in the nestest way thought you guys may have few ideas ? if not will do the the remainder first and work out some cuts to get me back ? All the best Kop
Yes I see your predicament now - you’ve centred the outlet with a joint!
So as you say you’ll have to recut away to the side to continue the bond line of the tile widths. May have been a larger cut to both side walls with a tile centred on the drain outlet and then to follow the bond up the walls.
It’s always a personal decision in the end. Unless your working for an engineer or architect, then anything whimsical can happen.
Wayne Brown,
Waluigi,
Wayne Brown,
Waluigi,
