R
Richard Edwards
I've decided to buy a Dewalt D24000 when my Rubi ND 200 packs in, which I expected it to do long before now, but still going strong, even after a serious amount of heavy work - code for abuse ! - That said - this Rubi model is the table saw model - not the overhead rail your talking about. I dont know how effective the Dewalt will be at cutting switchboxes out of whole tiles as the smaller the dia of the wheel, be better it is at that specifc task.
I would suggest that if you can afford it, buy a Rubi ND Model 200/250 stainless bed and also a D24000. The Rubi table top version as one massive advantage over every other type of wet saw - inc our DR300 EN ! in that it will cut any length of cut - infinity [as long as you can support the tile and the cut-off. ie we have cut 1200mm porcelain on ours, whereas the D24000 is limited to about 800mm or something like that - not sure without checking but my memory [going as rusty as my Rubi !] says its 750/850mm ish !
Hope this helps
PS - Dave at Tiletrader knows I will give a call one day - Just not yet.
Hope this helps
